I’m gradually rewriting a Python plugin into C# code. Eventually everything will be native, but for the time being I’d like to find a way of accessing custom Python classes from C#.
Python class goes in as GenericParameter and is referenced in a static GH_ObjectWrapper python variable. I can see all the content in the compiler, but its Value field is not accessible.
Once you get the first Value from the GH_ObjectWrapper (which you should be able to access) you might try casting it to a dynamic, and then drilling into its properties from there.
so something like:
Awesome @andheum!
The trick was to cast it to a dynamic, previously I was trying to cast to object and kept getting an error, that my object doesn’t contain a definition for ‘geometry’.
Thanks to your help, I can now access all the geometry within my python class directly from another C# component.
protected override void SolveInstance(IGH_DataAccess DA)
DA.GetData(0, ref python);
List<GeometryBase> outputGeo = new List<GeometryBase>();
dynamic pythonObject = python.Value;
foreach (var element in pythonObject.geometry["People"][0])
outputGeo.Add(element);
DA.SetDataList(0, outputGeo);
