I would like to ask Rhino to run “Loft” such a window of the command, the drawing area can only view cannot choose objects or other action. The function and how to make it come true.
So you got the curve ID’s already stored somewhere for loft but you still want the popup shown like you normally run the loft command?
Your question is still a bit vague.
In addition;
I mean, for example, the implementation of “loft” after this command, it will pop up a parameter setting window. This time, all the objects in the drawing area are not editable, can only view, rotation or zooming.
On this issue, what method can like this pop up window all the objects are not editable, can only view.
So you want to edit the objects while the form is popupped?
I mean that I want my drawing area just want to be read only(rotate or amplify ) , do not allow others to edit, how to make it ?
Oke now I understand.
Should the loft also be saved or is it just temporarily?
If so, you can use a DisplayConduit. If not, then I only know Lock but thats easily unlocked.
temporarily !
oke
Imports Rhino.Display
Imports Rhino.Geometry
Imports System.Drawing
Imports Rhino
Public Class PatchConduitLeft
Inherits DisplayConduit
Private _bbox As BoundingBox
Dim 'Brep as Geometry.Brep = Br.Brep 'Defined somewhere else
Protected Overrides Sub CalculateBoundingBox(ByVal e As CalculateBoundingBoxEventArgs)
MyBase.CalculateBoundingBox(e)
e.BoundingBox.Union(_bbox)
End Sub
Public Sub New()
_bbox = Brep.GetBoundingBox(True)
End Sub
Protected Overrides Sub PostDrawObjects(ByVal e As DrawEventArgs)
e.Display.PushCullFaceMode(CullFaceMode.DrawFrontAndBack)
MyBase.PostDrawObjects(e)
Dim vp = e.Display.Viewport
e.Display.EnableLighting(True)
e.Display.DrawBrepShaded(Brep, Mat)
End If
End Sub
End Class
This is an example of a DisplayConduit. Brep is only shown! It is not editable.
To activate this you must decalere it somewhere like
Dim DisplConduit as new PatchConduitLeft
DisplConduit.enable
More examples and explanation can be found on the forum. Just search for DisplayConduit.
Or here: http://wiki.mcneel.com/developer/rhinocommonsamples/drawoverlay
Thank you very much, I try
