I have a question!
When creating the cross-sectional shape of a column, is there a way to change the width of the top and bottom ends? (I want to create a tapered shape)Please check the attached document
Question about Crosssection.pdf (344.1 KB)
Karamba’s beam element doesn’t allow for variable crosssections directly. Use “manual” discretization with some GH logic instead. The Karamba team uploaded an example of how to do this some time back. See attached example and use similar logic to modify the parameters before input to the Modify Crosssection component if such a modification is needed.
180802_TaperedIBeam_cp_02.gh (22.4 KB)
