About exporting Layers from Rhino 7 to 8
Hello
I have created many Layers in Rhino7 and have assigned custom settings, environments, etc. to each layer.
Is it possible to import them all at once from Rhino7 and export them to Rhino8?
best
Not sure what you’re talking about, but have you not tried just opening your Rhino 7 file in Rhino 8?
Since I have different settings for each layer in this way, I am wondering if it is possible to import and export just the layers.
I have a custom Rhino7 template that I have saved, is it OK to load it in Rhino8?
Should be, just try it?
That said if you are using Raytraced and Rhino Render there may be issues with Custom material. Not sure yet if environment map is broken or not. addendum: environment map still works, it is bump map that is broken on rhino custom in rhino 8.
