Thanks for your reply.
That is not the problem. I have Iter set to 100, wrtiteIt to 10 and TSteps to 10 but still only time step 100 is reconstructed. I do see time steps 10-100 in the processors folders, so it does write correctly it is just that reconstruct is not working.
And a second question - how do I change time step in the probing component? Or do I always show the last time step?
You canât directly from Grasshopper at this point. We are running a steady-state simulation in which it makes sense to always look at the last iteration that has been simulated.
If you really would like to look at any other iteration:
Open the BlueCFD terminal
Navigate to your case folder C:\test
Adapt and run this command: postProcess -case 0 -func ttt -time 100 | tee -a log , where 100 is the iteration folder you would like to probe and ttt is the name of your probing instance.
Is there an example of including terrain geometry in Simulation Domain? It says âMake sure the terrain geometry is bigger than the ground plane of the wind tunnel.â Not sure I understand it. Anyone can shed light on this will be greatly appreciated.
But why do I even need to specify the WriteIt and TSteps then, since that shouldnât influence the simulation?
You donât have to specify them but you could if you wanted to. Some users might find it useful when working on advanced analyses.
When using any sort of ground surface that is not flat, make sure that it extends beyond the ground surface of the wind tunnel, see below.
I just tried some cases with Eddy, really impressive !
Is there a way to output and get the total drag resistance (Fx) value ?
Best regards,
Mathieu
hi @anon39580149. Can you please share your script to check. To answer your next question eddy doesnt have such feature as it becomes quite complicated to generate heavy mesh inside rhino. Paraview is intensively for that.
