A viewer for PC and Mac
Hello, I would like to suggest that you consider creating a free, no-login viewer for PC and Mac, currently, only the iPad app allows this.
I am currently working on a complex industrial site project involving several buildings and all the interior equipment.
To allow clients to view the files in 3D we use the Fusion360 application which allows us to create a link to a Web viewer that the client can open without any installation.
This is very convenient, but in my current case, importing requires redefining all the materials for every object, and there are many objects which is really a waste of time since everything has already been done in Rhino.
For the first time, I used Rhino 8 to complete an entire project. The version is finally stable and I was able to notice a clear improvement in display performance compared to version 7. Also, Rendered mode produces really clean images for sending a 3D model to a client. (We are indeed talking here about Rendered mode and not Raytracing)
My client is a promotional and commercial department of a large company.
I discovered that they had no way to view 3D files, whether the Navisworks files from their internal engineers or my own 3D files regardless of the export format.
To avoid using Fusion 360 I suggesting that the client install the F3D software, but the rendering is not very attractive, and its open-source nature gives it a less “pro” to some people.
Having a PC and Mac viewer that would allow us to secure and share our 3D models could be both very useful for us and a great showcase for Rhino.
And if this application can open various file formats, that would justify asking our clients to install it.
jmv
Hi -
Perhaps one of those?
or
Thank you @wim
It is indeed this kind of application. I have just tested them. The first solution was not able to open my optimized file (500 MB), and the second produced many errors and once again the rendering is not very attractive.
In fact, this last point would really be the added value that an official application could bring. Of all the viewers I have been able to test, what is displayed in Rhino is never what is displayed in the viewer. Unless you find a viewer that use exactly the same GPU rendering shaders, it is currently pointless to define materials and colors in Rhino, given that you will have to redo everything in the visualization software intended for the client.
The other thing that bothered me about sending the 3D file was precisely sending the 3D file. The advantage of Fusion 360’s web viewer is that it is possible to disable the ability for clients to download the 3D model.
A native application that produces exactly the same rendering as defined in Rhino, while sending files that can only be viewed, are features that I have not found in any other solution.
And if I had the choice, I would greatly prefer to send a viewable file through our communication channels with the client, so that they can open it in a local application, rather than having to transfer my files to Autodesk’s servers.
Have you had a look at https://viewer.autodesk.com/.
It’s online operates on Windows & iOS, computer, tablets, phones.
In our recent update, we confirmed that heavy models over 1 GB open without any issues. If a 500 MB file is causing problems, it may be due to a regression in the update or an issue specific to that particular file. Would it be possible to share the file with us, as long as it doesn’t violate any security or confidentiality policies? (jy.go@plusplastic.com)
If you search for and install byRhinoViewExport via the PackageManager, you can export your 3D models directly as HTML files. It also offers several options, including password protection.
Files larger than 1 GB are also supported.
We tested it with a 1.9 GB file.
Thanks, @Jean-Go
Thanks to the plugin, I was indeed able to export the model to a single HTML file, which is a great solution. I really appreciate being able to send a standalone file that runs locally without any prior installation.
However, while the rendering on the HTML page is very good, it doesn’t quite match the setup defined in Rhino.
I ran into a few issues:
  • Materials are handled on an object-by-object basis, with the same material being duplicated for each object. This means the material has to be modified separately for each object, even when they all share the same one in Rhino.
  • The export didn’t preserve the “Size” setting defined for the texture image, so the texture scale is incorrect.
  • The export also does not support assigning different materials to individual faces of a single object.
I also noticed that the Three.js scene graph and rendering are updated in a continuous animation loop, even when the view is not moving.
For large models this causes unnecessary and significant GPU usage. To my knowledge, aexcept when using the Bongo plugin or slider-based animations in Grasshopper (which cannot be exported), a Rhino model remains static. Not all of my clients have a powerful graphics card in their desktop or laptop computer.
I also found that it is impossible to export using the “Export Selected” command. I have to first export the objects intended for HTML format into a separate 3DM file, open that file, and then export it to HTML.
Since all materials, even identical ones, are duplicated for each object, I assume the objects aren’t grouped by material. Yet, grouping by material is the most effective optimization. The downside of course is that selecting an individual object becomes more difficult.
There are also some editing features I would like to be able to disable, such as the properties panel that appears when an object is selected, or the layer list.
I saw that the HTML page source code is available on GitHub. Is the Rhino plugin source code available as well? I find it to be a very handy solution and would like to experiment with some improvements.
I continued experimenting with this solution and achieved results convincing enough to decide to test it by sending the generated HTML file to the client.
However, I took a different route instead of using the Rhino plugin:
  • I exported to GLB, which is very fast and preserves the texture scale, and per-face material assignments.
  • I then used the script available on https://gltf.report/ to optimize the file and group objects by material.
  • I used byRhinoView to adjust certain environment settings, such as ambient occlusion (AO), before exporting the final file.
The result is that the rendering is extremely smooth. A 500 Mo file was reduced to an 18 Mo HTML file that can be sent by email.
The client just replied with an enthusiastic “Thanks, that’s great!”, so I assume it works perfectly on their side, even though they probably don’t realize yet that it drains their battery before their eyes… :slight_smile:
