I am doing udpclient these days,
just want to get a UDPclient instance by a port number(int).
it sounds easy.
but I find a strange problem…and it problem take several days and still unsolved…
this my code:
protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
pManager.AddIntegerParameter("LocalPort", "", "", GH_ParamAccess.item);
protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
pManager.AddGenericParameter("UDPClient", "", "", GH_ParamAccess.item);
UdpClient udpClient;
int localPort;
protected override void SolveInstance(IGH_DataAccess DA)
if (!DA.GetData("LocalPort", ref localPort))
return;
udpClient = new UdpClient(localPort);//put a breakpoint here
DA.SetData("UDPClient", udpClient);
the error message in English is:“Only one usage of each socket address(protocol/network address/port) is normally permitted “.
i use “netstate -a” to check the net socket usage ,i am sure every time the “59153"port is available to use before launch Rhino and grasshopper.
so I go to debug ,i add a break point at"udpClient = new UdpClient(localPort);”,then i find when this breakpoint is hit, i see the udpClient is null and then be given a newUdpClient(localPort) ,it is i want and nothing error happens when be given a newudpclient.so in normally,the solveinstance() should stop after " DA.SetData(“UDPClient”, udpClient);”…but no…when i press continue …the program stop at breakpoint second time!,so udpclient is null again!(it should be not null because already has been set),and it will be given again with same portNumber,this is the source of error"collision of port”.
I just donnot know why the solveinstance run twice …
(and i found solveinstance sometime run one time,and sometime run twice…)
Thank you for explain!
