Hi to Rhino Developers,
If objects show their own object color in clipping plane - section mode, it’ll be much more convenient to differentiate and so evaluate their relations.
This works if you use “Viewport” for the clipping plane fills - and do not have color backfaces set. It would be good if this worked even if color backfaces was set - as the clipping fills are not really “backfaces” IMO. I only tested this in V7, not in front of my V8 WIP install for the moment.
Hello Helvetosaur,
Thanks for the quick reply. I could not find the setting you mentioned, unfortunately. I did not see anything in ClippingPlane | Rhino 3-D modeling too. Could you please show how to do it , if possible?
Edges, no, Fills, yes - it is the setting just above the one you showed. Colored fills only work with closed objects though.
Thank you so much,
Hi Sirin -
Showing the clipped edges in the object’s color is implemented in Rhino 8:
I added a comment to the youtrack item.
