Could someone give me an alias for turning on Zebra and when it prompts you to select your object to have it select all and then to turn if off? I would really appreciate it.
Thank you
Thank you
@cosmas In Rhino 8, you can put this code in a toolbar button and it will toggle zebra on all breps. FindByObjectType
can be adjusted for other geometry types:
_-ScriptEditor _Run (
// #! csharp
using System;
using Rhino;
using Rhino.Display;
using Rhino.DocObjects;
var doc = Rhino.RhinoDoc.ActiveDoc;
var zebraMode = VisualAnalysisMode.Find(VisualAnalysisMode.RhinoZebraStripeAnalysisModeId);
foreach (var obj in doc.Objects.FindByObjectType(ObjectType.Brep))
obj.EnableVisualAnalysisMode(zebraMode, true);
Thank you!
