hi every 1:
I want to square a rage of numbers with evaluate.
I put the expression X*X on the expression or in the panel as the figure below but there is a problem.
Any1 to say what should I do?
thx a lot
hi every 1:
Disable ‘Display | Draw Full Names’. Or maybe you are using uppercase ‘X’ instead of lowercase ‘x’?
But you don’t need Evaluate for something so simple, you could use the Sqr (Square) component under ‘Math | Polynomials’.
Or right-click on “Variable x” and type “x” instead in the context menu.
thx all
it was helpful
