Following this discussion
I looked at a way to smooth a jagged mesh with holes. The idea is to have a mesh with holes but no non manifold vertex/edge/face. For each hole a polyline is extracted and smoothed (like in the Grasshopper component Smooth Polyline).
Then for each naked vertex its vector displacement is calculated in order to go to a point on polyline (there is the option for closest point BUT it is not good).
Then displacement vector are calculated for the whole mesh.
These vector are used to calculate a new mesh. Then the mesh points could be projected (using mesh closest point) on a reference mesh if needed.
This need Nautilus 2.1.3.
here a mesh with some holes (you will notice some non manifold vertex)
This method doesn’t give the same result as Laplacian Smoothing or mesh subdvision. It can smooth holes also if mesh is fine.
smooth holes Cow.gh (30.1 KB)
The difference between Catmull & Clark subdivision (top left) and the other
smooth holes Cube Smiley.gh (26.3 KB)
