A method to scale moving/Pushpull a face?
I’ve been using Rhino since 2015, but every time I come back to it, I learn something I should have known. So here’s a question. I occasionally run into this where my distances are slightly off. I want that distance to be 3mm. In this case, I can just do the math. Sub-select the face, and move .11mm. But I was wondering if there are other ways I can do this. Some way to say make the measured distance 3mm. Maybe Scale, PP?
Hi @CalypsoArt
I would use “from snap” but it appears not to work properly in V7.
If it worked you could set your base point at the opening and type in 3 and it should move the face to 3 not add 3 to the current face location.
You could draw a line type in 3 and use shift tab to constrain the line to ortho. Then use that as a guide to snap to.
I think from snap should work being invoked by ctrl key in the move command over the snap toolbox, but doesn’t seem to be any different when using the move tool.
RM
@CalypsoArt I use Scale1d for this all the time. I have it mapped as an alias - ‘S1’. For context I use rhino for interior design and this provides good results for me, but I don’t know if this approach is best practice
  1. Turn Ortho on
  2. Sub select surface to move
  3. _Scaled1d
  4. Pick internal point to scale from
  5. Move along Ortho line to find perp snap at surface edge
  6. Pick second point
  7. Type 3mm
I think this might do it. I wonder if this could be a script? I hear people are using AI to code. How would I have it create this script?
Hi Calypso -
What would you script?
It’s very unlikely that the surface, the base point, and the final distance would ever be the same in two different occasions. All you need is to run the Scale1D command (which I also have as a S1 alias on my systems).
