A little bit of noise
Is there a reason why you used 2x Catmull Clark Subdivision set to Level=1, instead of 1 set to Level=2?
That is because the subdivision level can only go up to 3 for one component. But sometimes I need to make it 4 or 5 to add details.
Hello.thanks for sharing. Would you please tell me about 2components?pOd_render material test and also the colorfull component which name is unreadable.
pOd is not necessary.
You can just use Custum Preview to do that.
Make a material in Rhino, use that in GH with the Custom Preview.
