Hi.
I am looking for a command , function or menu that evaluates a object and tells me it’s outside dimensions.
Currently I draw two construction lines and jog them in to the object or snap to the outside edge of the object if I can. Then measure between them. Or I place a point at each end and use evaluatept. Then work out the difference.
Is there a ‘just’ button I can press that tells me the dims of a outside of the object?
I use the following for visualization purposes. I draws a ghosted (world-oriented) box and 3 text dots of X, Y and Z extents. The box and dots are grouped for easy deletion. The values are also reported on the command line.
