This is super strange… I have around 1000 polylines in this file, which consist each out of 4-10 line segments, and the file size is 5 GB.
I checked if it could be anything else, purged the file, but it seems to be this relatively dense chunk of polylines. When I export them, the exported file is equally large.
7565402 bytes, id = 027e18ea-df92-4e2f-97e5-d7677f7bcb5f, name = "Curve: PolylineCurve m_pline[] is not valid."
That would do it. I recommend selecting the objects you care about and running Invert - is anything selected? If so, Delete. If not, Export to a new file…
Question is, how did this happen? if you run SelBadObjects and find anything, please send us one of those.
There are almost no bad objects. The red polylines were baked from GH but something must have gone terribly wrong. If I explode them the file becomes even bigger although they are just single lines?
In GH, I made a convex hull around a hand full of points. They resulted in Polyline Curves, and I only baked those that were valid.
I have uploaded the whole file here if you want to have a look. I might have to look more into the GH process to figure out what went wrong.
Yup, that was it. If I selected one item and switched to view the user values Rhino would get stuck trying to show what looks like a LOT of text. I was able to select them all, in which case the text wasn’t shown, and I deleted all values. Back to 8mb.
Grasshopper only includes data on baked objects when they are baked using the Geometry Cache object. Regular bakes do not add any user texts. However it is possible that objects are baked via scripts or plugins in which case the behaviour might change.
So yes, knowing how this happened would be of interest.
This is very strange but then again I used a really old GH definition that I changed around a bit to get the result. That shouldn’t have had any effect on the geometry though:
I used collections of points to make convex hulls, then I used the group component twice to have nested groups one to group each branch, the other one flattened the whole data), then I baked the last group component using the right click on the canvas.
Getting nested groups didn’t really work when I checked the baked geometry it was just one group) but I didn’t really care and kept baking multiple instances of it.
There’s not enough information in this last post of yours for us to be able to determine how user text was added. Are you able to post a Grasshopper definition that lets us reproduce that behavior?
I was baking a group component which had like 1500 curves and 14k curves turned into 7GB file! After reading this, I baked the same by insert command and it was 5mb… It’s incredible how there can be such a difference.
