A fantastic object
I think this would be worth a look with a more reflective environment. I like the geometric form across the surface.
I it’s gold, I’d consider turning down the roughness in favour of better reflective properties.
You are right :slight_smile:
Of course it is a print view, not render.
Also, my purpose was to show the design itself, not an object with whole realistic appearance.
If I used render and an appropriate ground, it would be so much better.
Sadly, I deleted its file after getting a print, and if not, I would change it as you recommended
