A decorative wooden bird
Hello
This is a wooden bird I designed as a decorative thing
Nice!
Would you mind if I asked what methods you use to generate the surfaces?
I just used two simple curves as the rails and then used two other simple curves for sweeping. I finally used sweep2. At the end I used mirror, boolean and wood material.
The important issue is that the rails have the shape of a bird.
That’s a really nice sculpure and model! Congrats!
So the sweep shapes is in the middle of the rails, and two end points of the rails are choosed as the beginning and finishing of sweep2. Is my guess correct?
Yes, you are right :slight_smile:
I divided the rails into two parts
Fun!
