A couple of V8 UI questions
I’ve brought this up before, but sometimes the squeaky wheel gets the grease.
Are we ever going to be able to dock the vertical toolbars for layers, properties, etc. on either side of the panels?
Secondly, is it possible to stop the icons from jumping to the top in the recently used toolbar? If not, is there a plan to make this an option? I notice it still does it in the V9 WIP.
Thanks,
Dan
Bump.
Hi Dan,
I’ll get these added to the wishlist. Do you think that having the MRU item not move should be the default behavior?
https://mcneel.myjetbrains.com/youtrack/issue/RH-85140/Allow-panel-tabs-on-opposite-side
https://mcneel.myjetbrains.com/youtrack/issue/RH-85141/Dont-move-MRU-button
Hi Steve,
I do. It’s super handy when doing repetitious tasks to use the MRU toolbar. But when the icon you pick keeps jumping to the top, the “muscle memory” used to repeat the process over and over can’t happen because the toolbar keeps changing. It’s not that big of a deal if it only involves a couple of icons, but when a process is using quite a few icons it becomes pretty frustrating.
Thanks,
Dan
RH-85141 is fixed in Rhino 8 Service Release 16
