A command to show and highlight all non-default icons and toolbars?
In my opinion, Rhino needs a command that can open all hidden toolbars and highlight all icons that contain customized commands, i.e. everything that does not ship with Rhino by default. Running that command again should return the previous state of the toolbars. Sort of a Toolbar state manager, maybe?
Also, a command line option of this icon must let the user choose if the highlight of all non-default icons will remain permanent (like changing the background colour, adding an outline, or a tiny triangle or a plus symbol in the corner). It must be possible to remove the highlight at any time.
Would a button from the core Rhino button set placed on a custom toolbar be considered non-default? What would you use this highlighting to achieve?
Since it’s copied or moved to a custom toolbar, it should be highlighted as well. Just like anything that’s not default.
The highlighting will help the user see which icons were modified, thus they could be checked for errors, for additional modification (or removal) or when the user forgets where he or she placed a certain icon.
If you delete a button from an existing toolbar, that toolbar is no longer “default”. Should this be highlighted somehow as well?
I believe that this should be considered a non-default toolbar, too, despite the fact that it does not contain a new or a modified icon. It just lacks one default icon, but the remaining icons on the toolbar are totally default. In this case, I think that there may be some highlight on the toolbar itself, but not on the default icons.
There must be a right-click option to each toolbar, so that the user could return the default state (reset) only the selected toolbar, while the rest toolbars remain unchanged. Currently, Rhino allows to reset all toolbars, but this will delete forever any customization. Many times the intent is to reset just one specific toolbar instead.
Thanks; I’m heading out for a bit but will write up a wishlist item for this when I get back.
Thank you. That’s a much needed feature that could help many Rhino users. Especially the ability to reset an individual toolbar only.
https://mcneel.myjetbrains.com/youtrack/issue/RH-83289/Show-Modified-Toolbars-and-Reset-Individual-Toolbars
Wish logged
