a.3dm (2.4 MB)
Hi @Hulki_Aydoğmuş
The highlighted edge is waaaaay out of tolerance. If you untrim it, the other commands should work as expected. Do you remember how it was originally trimmed?
HTH, Jakob
Hi Thanks a lot , after I made it , I must use extendsrf for enough size and I want trim with red area, I failed I started over with middle isocurve
