Hi Guys,
Updated my Rhino 8 this morning to Rhino 8 SR36 2026-10-6 Rhino 8, 8.36.26279.07001 and now I get this error on loading any of my plugins that contain Python Scripts:
Source code for DKUI is also broken:
Any fixes available quickly and will this effect my clients as well?
Cheers
DK
261008_Systeminfo.txt (2.7 KB)
SystemInfo attached.
In the DKUI source code, Python 3 components are working, IronPython components are broken.
Cheers
DK
OK - another symptom - after a PC restart, Rhino stalls on loading Grasshopper on a blank Rhino file.
hhhhmmmm.
DK
OK, I’ve found the source of the issue/a work around.
This error is showing an issue loading scriptcontext in IronPython.
On a hunch I set the DotNetRuntime from NetCore v10 to NetCore v8 and the issue was resolved,
Looks like something Eshan needs to look at ASAP.
Cheers
DK
MSAwan
( Muhammad Saqlain Awan)
October 8, 2026, 11:29am
7
Try if you can reload the ironpython from the tools. And restart the rhino
Hi @MSAwan
I had already tried that - with no luck.
Here is the difference in behavior highlighted between v10 and V8 DotNet runtimes:
Thanks
DK
Japhy
(Japhy)
October 8, 2026, 1:11pm
9
There was a change in Rhino 8.36 to .netcore 10 as default, NET 8 and 9 go end-of-life in November 2026.
Thats OK - and expected.
BUT
Ironpython now appears to be broken because of it?
Thanks
DK
Japhy
(Japhy)
October 8, 2026, 1:55pm
13
Got it, will see what Ehsan says but this might even be able to be a hotfix.
RH-99401 IronPython scripts fail on the .NET 10 runtime
same situation here… quite a big mess in the middle of a project
dale
(Dale Fugier)
October 8, 2026, 5:10pm
15
You don’t have to subscribe to downloading release candidates…
– Dale
i know, since 2003 when i began with rhino. Just never had this kind of issues
Hey Dale, must be some stress in the office ahead of the R9 release.
Always happy to find and report bugs from my side, I’d rather find them before my clients do.
Keep up the good work team.
Cheers
DK
dale
(Dale Fugier)
October 8, 2026, 5:26pm
18
No stress - Rhino 9 will ship when it’s ready.
– Dale
Japhy
(Japhy)
October 10, 2026, 5:49pm
20
It is but it doesn’t look to be pushed as a hot fix yet. Sending you a link.
Just installed the latest Release Candidate [Version 8 SR36 (8.36.26279.7001, 2026-10-06)] and still get the error. Should I roll back to the Service Release and hopefully it will work? Or maybe you can send the hot fix for this @Japhy ?
A bit annoying…
Thanks,
-A.
brian
(Brian Gillespie)
October 13, 2026, 9:55pm
22
