Hi David,
Thanks for the fast reply.
I have downgraded until futher notice and everything seems fine now.
I don’t have time at the moment to fiddle about with anything re crashes
My problems were across all the drawings I am working on so I think my Mac and 7.11 just are not friends at the moment.
system info as follows
Rhino 7 SR11 2021-10-12 (Rhino 7, 7.11.21285.13002, Git hash:master @ ca75d3c67ded62b7ad8856f48d5ef2d6d1d926be)
License type: Commercial, build 2021-10-12
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 10.14.6 (Build 18G8022) (Physical RAM: 8Gb)
Mac Model Identifier: MacBookPro12,1
Language: en-AU (MacOS default)
Intel(R) Iris™ Graphics 6100 (OpenGL ver:4.1 INTEL-12.10.25)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 1536 MB
Graphics: Intel Iris Graphics 6100
Displays: Color LCD (227dpi 2x)
Graphics processors
Intel Iris Graphics 6100 (1536 MB)
Color LCD (1280 x 800)
USB devices
Broadcom Corp.: Bluetooth USB Host Controller
Bluetooth devices
None
Third party kernel extensions
com.getdropbox.dropbox.kext (1.13.0) 4FFF485B-204E-3E48-BC54-C1D406AB9E75
Third party plugins
/Users/nickp/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/Trace.rhp “Trace” 1.3.1.0
/Applications/Rhino 7.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_X.rhp “X Import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_STL.rhp “STL Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Squish.rhp “Squish” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_Points.rhp “Points Import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_Points.rhp “Points Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/MPlane.rhp “MPlane” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_M.rhp “Import_M” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_STL.rhp “STL Import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_X.rhp “X Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 7.11.21285.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.11.21285.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.11.21285.13002
I hope this helps!
Cheers
Nick
