60. Measurable clipped elements
Please see video
The request is simply to be able to measure the distance between clipped edges of surfaces or polysurfaces. Currently, when you try to measure that distance, you cant snap to the clipped element.
Regards
Hello- yes, this is a common request - the clipped objects are not geometry in the document - in order to get these, you can intersect your geometry with the clipping plane - use the InfinitePlane tool, clicking on the clipping plane as the infinite plane, as one input into IntersectTwoSets for example - that will generate actual curves in place that can be snapped. Yes, it is a workaround… I do not know what prognosis is for getting snappable ‘non-geometry’…
