犀牛5的GH在拾取点的时候我可以先在模型中选中 然后在GH里set points来选取 犀牛6的GH怎么不能这样了 只能直接用set points来选取 有跟我一样情况的吗
, can you ask your question in English, please?
Edit: Good old GoogleTranslate:
“Rhino 5’s GH can be selected in the model when picking points and then set points in GH to select how Rhino 6’s GH can’t be like this. Can only use set points directly to select the same situation as me?”
