6.4 (italian language) - RhinoDotNetCrash [SOLVED in 6.4.18130.19341]
unhandled
#1
Hi to All
Windows 10 Home 1709 and feedback received with same errors also on Windows 7.
Starting Rhino 6.4 in italian we get a Generic error in GDI+ and the attached RhinoDotNetCrash.txt dump file is generated on Desktop.
RhinoDotNetCrash.txt (3.9 KB)
and continuing Rhino works but the Splash Screen looks like this
During the start this additional error is displayed
Command%20did%20not%20register
Thanks
  • Michele
Rhino 6, problemi dopo l'installazione dell'ultima service release
Rhino 6 CRhCommandManager error
Errors pop up after installing Rhino 6 SR4
#3
I have confirmed that other users (italian) have the same problem when starting Rhino 6.4, the same pop-up window.
(Brian Gillespie) #4
Thanks, I’ve logged these bugs (which I believe are separate) as: RH-45961 and RH-45962.
#5
Thanks Brian. They ask me: “For the resolution of this annoying pop-up in startup, will we have to wait for the new service release?”.
Thanks
(Brian Gillespie) #6
No, we’ll put out a hot-fix for SR4.
Rhinoceros 6 Error: "Command did not register"
(Brian Gillespie) #7
RH-45961 and RH-45962 are fixed in the latest Service Release (6.4.18130.19341)
