Capture to file feature is one of my favorite in v6, i really need it to work properly.
It is broken from 6.14 i think. Parallel view is moving somewhere down if you try to change resolution.
Please fix it ! Thank you!
Hello - does it help, for now, to maximize the viewport before the capture?
Maximum that i can get is 1920x1080 and this also work with predefined value from drop list. Everything above is broken. Now i am capturing viewport like in old times by parts.
Thank you @bigonethegod, I can reproduce this and have created the following YouTrack item: https://mcneel.myjetbrains.com/youtrack/issue/RH-53656.
-David
Thank you!
