5 Sided Hole Problem
Dear fellow Rhino users,
I was wondering if you could help me solve this 5 sided hole problem I came across.
I am familiar with the thirtysixverts series on Youtube, but still somehow got stuck and can not come up with the right solution. I tried dividing the surface into two 4 sided surfaces (split by the blue line). Yet still the results are dissapointing, since the outcome surfaces are quite pointy on one end.
I am on Mac so XNurbs unfortunately is not an option…
I would really appreciate some input and help on this!
Best,
Leonard
5 Sided Hole Problem.3dm (251.4 KB)
Looks like a good old “Y-fillet” situation. What you certainly don’t want to do is to have four sided surfaces where two adjacent boundaries come to a point, as the blue line indicates.
I was looking at your file. It looks like the surface to the right side of the hole has an undercut or negative draft to it. Is is your intent?—-Mark
If you have Rhino 8, you can use your license to access the Rhino 9 BETA, which includes a new patching tool that is nearly as good as XNurbs. Here is a link to the Rhino documentation for this tool: Patch | Rhino 3-D modeling
-Robert
Rhino 9 is also available for Mac.
check this topic for some inspiration:
See what @Lagom posted as an advice. This is the most commonly used approach in NURBS surfacing.
Here is a short video tutorial for a similar case:
Thank you so much for all of your responses!
I have found a patch layout which might work, but even after using _MatchSrf I can not join all of the surfaces togegther into one.
It would be great if you could let me know if I am going into the right direction or if someone might have a better idea for patch layout.
5 Sided Hole Problem New approach.3dm (2.9 MB)
1) I first created the blue surface by creating a surface blend between the purple and the red surface.
2) I then created the green surface by slightly splitting the left edge of the purple surface and then creating a blend with the yellow surface.
3) Using the pull command I then used the bottom edge of the green surface to trim the blue surface.
4) Next I copied the trimmed edge of the blue surface to rebuild into a single span curve. I then created the green surface with the command “surface from edge curves”.
The result looks promising, but unfortunately there seems to be a gap between the green and the blue surface which I can not solve using the _Matchsrf command.
Any help would be greatly appreciated. I did try the Rhino 9 Beta patch command, but unfortunately the command was struggling as well with this 5 sided hole.
Best,
Leonard
I don’t have a solution – for this exact situation – but wanted to comment on ways to work better. I used to get into the ‘model yourself into a corner situations’ before reconsidering this workflow. The demos that show how to patch oddball holes should first show how to avoid those in the first place! Some tips
  • First, analyze the overall form.
  • Then, strategize the best way to build it : try to build it in minimal surfaces / trims / passes.
  • For example, I purposely modify my designs to avoid 3 or four fillets sizes all colliding into a single point. Just say no!
Many forms that switch from blending to hard surfaces will benefit from Sub-D, providing you are comfortable with creasing.
See above.
my guess: to get a nicer transition you have to
  • provide more space for it to happen.
  • make more rectangular like corners wherever possible
  • as simpler the surrounding surfaces are, the less trouble. check with
    • _curvatureGraph and avoid inflection points ( at the edges (the violett surface changes curvature side / s-shape curvature graph)
    • optional: _curvature (check if the principal curvatures are close to the isocurves - which is not a must, but easier for the next hierarchy of surfaces )
… and now trying to fiddle it more i crashed rhino 9 ;-(
EDIT:
more fiddling…
5 Sided Hole_02_tp_forum.3dm (250.2 KB)
happy modelling - kind regards - tom
Thank you very much Tom, great result!
Dear Tom,
​​​​​​​​I am curious about how you created the red surface on the left. Would be great if you could let me know a bit more about your thought process and surface creation on this specific problem, just so I can understand a bit more.
Best,
Leonard
@Leonard6 I think your original red surface differs too much from the purple. This makes the transition surface having to do too much work.
If patch doesn’t give you nice results it is often because of the boundary constraints.
In the attached, I created a patch that runs all the way to the left of the red surface, giving it more room to flow
5 Sided Hole Problem-01-patch.3dm (627.0 KB)
@gijs
nice result - what settings / parameters did you use for the patch ?
You can double-click the patch to see it, but it’s just defaults (Molded)
The purple surface had to be matched first, as there was a 10+ degree kink at the upper left corner
My advice it to always take extra caution on the control point weight, because some tools of Rhino change the point weight secretly, thus causing various issues with matching the adjacent surfaces. I made a few videos about that topic on my YouTube channel. I also shared this issue here on the Rhino forum in several topics. This is a common mistake made by many users.
If it was mine project, I would fix the input surfaces before trying to fill the 5-sided hole.
See what happens when the geometry consists weighted control points:
I’ve come around to using the patch command for small size difficult openings. I trim out any edge continuity issues then close them with a 4 sided surface. If it looks smooth and shells I’m happy.
of course, the surfaces can be improved a lot. AFAIK Patch doesn’t have issues with these point weights though.
Patch is not only a great modeling tool, but also functions as canary in the coalmine. If it behaves badly you need to fix the boundary conditions.
Here’s an example where Patch creates a very nice transition once the boundary surfaces are fluent
5 Sided Hole Problem-01-patch2.3dm (3.7 MB)
Nice example. Was waiting for that one.—-Mark
