I have a little problem: I often change the dimension of the 4 default viewports in Rhino 6 during modelling with VisualArq. When I click on “4 Views” in the Standard Toolbar of Rhino 6 some views became completaly black… any suggestion?
Could you post the result of the Rhino SystemInfo
command in a reply here?
Ok!.. But how can I do it?
In Rhino 6, run the SystemInfo
command. That will pop up a dialog with text information. Copy that text and post it here.
Rhino 6 SR3 2018-3-31 (Rhino 6, 6.3.18090.471, Git hash:master @ b32d93f452fce970e96deb46bfc68b075f06b290)
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
GeForce GT 650M/PCIe/SSE2 (OpenGL ver:4.5.0 NVIDIA 369.09)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 8-1-2016
Driver Version: 21.21.13.6909
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino 6\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
Please update your GPU drivers. That will most likely take care of this problem.
Great, it works now. Thank you!
Ehm, however a note. Sometimes with the Realistic (Visualization Mode), there is the problem again…
Is the Realistic
display mode the only one that you are having problems with? What about Rendered
Also with Rendered there are some problems…
