3MF file opens with missing components in BETA
The 3MF file opens correctly in Rhino 8, but in the BETA version, it opens with some content/components missing. (Rhino 9 BETA, 9.0.26230.12303)
63ro (1).3mf (5.5 MB)
Hi :slight_smile:
Just to add to @Jean-Go’s observations: on my PC the Beta opens 32 duplicates of the terrain block in the file (and also no buildings) :grimacing:
-Jakob
Edit: Just to add again, and this might just be a coincidence, if I explode the block in Rhino 8, I get 32 meshes, so there’s actually 32 objects in both files. In Rhino 8 it’s 32 meshes in one block; in the Beta it’s 32 blocks with one mesh. Maybe some wires got crossed :thinking:
You’re right. Checking another file now, the number of duplicated terrains in BETA matches the exact number of objects contained inside a single block in Rhino 8.
Thanks, @Normand
Thanks for reporting this issue.
→ RH-97875 File IO: Import 3MF Problem
RH-97875 is fixed in Rhino BETA
