3DS export taking very long time for some seemingly simple model files.
Using Rhino 7
A problem file attached. It has 376 surfaces and takes about 20 mins to write the 3DS file, making the work I need to do unfeasible. heat loss envelope L03 to L06 tester 01.3dm (1.8 MB)
I don’t think it is the meshing step, as when manually mesh the model, this works fine and quickly.
Hope someone can advise on how to speed up / fix.
Regards
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display and OpenGL: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 3-3-2023 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.2121
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 31.0.101.2121
Driver Date: 3-3-2023
Driver Version: 31.0.101.2121
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\Pollination\1.40.2\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.40.2.0
c:\Program Files\Solemma\ClimateStudio\bin\ClimateStudioRhino.rhp “ClimateStudioRhino” 1.9.8389.22035
