Hi Luis,
I’m trying to setup example files for our developer and find that not all curvetypes are supported.
Rhino file:
test_curves.3dm (42.3 KB)
imported in https://threejs.org/editor/
It looks like polycurves are not supported yet.
Is there some documentation or can you point me to the code where I can find what types of curves should already supported?
EDIT @Luis I fount this code , but I’m not sure if I an make sense of it.
Further test makes it appear as if the curves are not rendered.
I exploded 1 curve as a test, and that does show up, bot I found that some curve object are selectable but not visible. Maybe due to the 100 point limit?
All in all very promising as it will eliminate a time bottleneck in our current coversion from Rhino to web!
Thanks
-Willem
