Good morning,
I try to open some old files I made a few years ago.
Unfortunately Rhino won’t recognize them.
They are 3dm files, and grasshopper files are corrupted too.
How can I solve this problem ?
Many thanks
Dominique
did you try the command Rescue3dmFile?
Good Morning,
I try to use it.
Apparently, there are some problems with
ERROR Read3dmStartSection() failed
So I still not get it.
I try to recover it buut nothing coming … gosh
Dominique
can you post one of those corrupted example files? sometimes there are additional files lying around with the ending bak which you might be able to open.
Verrine_Essai_08.gh (224 Bytes) Verrine_Essai_08.3dm (294 Bytes)
This is a exemple. Rhino file with Grasshopper study
these seem to be some temporary files. i am not sure i can help you further here, you have to look where else you could have saved that files
analyzing them i found the following
thats all that file contains.
the grasshopper file looks similar
Many thanks for your help.
It seems I have to find back the original files,
Regards
Dominique
