3DFace with RhinoCommon
What is the easiest way to create a quad mesh with one face from 4 points–like the Rhino command 3DFace? Can this be done simply with Grasshopper components?
Yes, all you need are these components:
Thanks! I imagined there must be a simpler way to do this.
In GHPython, you can do this similarly with the API:
import Rhino.Geometry as rg
pt0 = rg.Point3d(30.861632, -25.282937, 0)
pt1 = rg.Point3d(32.915315, -17.996112, 0)
pt2 = rg.Point3d(42.359933, -22.419548, 0)
pt3 = rg.Point3d(41.672351, -28.502883, 0)
vertices = [pt0, pt1, pt2, pt3]
mesh = rg.Mesh()
for vtx in vertices:
    mesh.Vertices.Add(vtx)
mesh.Faces.AddFace(0, 1, 2, 3)
a = mesh  # GHPython component output
