3DConnexion SpaceMouse SpaceNavigator control reversal
Control direction reversal of Space Mouse / SpaceMouse after updating V9 WIP may be due to the “mode” having changed. To switch mode go to SpaceMouse > Popup_Menu
Can you be more clear on the reversal issue here. There are a couple items to track here and I want to make sure I have enough detail to explain it.
@scottd My post above was not a report of a problem.
Rather it was intended to “informational” for users who encounter control direction reversal prolems with 3DConnexion devices when using Rhino 9 Beta. My recollection is there were several reports of such problems around the time I posted this.
It’s possible not to be aware of the Rhino native Spacemouse settings panel (I wasn’t).
Had always configured the Object Mode setting selection from within the 3DConnexion Configurator App - with its program-aware setups. Perhaps Rhino silently inherited this configuration? Don’t know because it “just worked” in v7 & v8 - but around the time these reports of issues began to arise with users of the Beta having their settings suddenly seemingly reversed, (perhaps due to the defaults at launch not respecting (or perhaps attempting to respect and re-reversing a binary value somewhere?) the configured state) - that is the point I believe I first became aware of the in-Rhino Spacemouse command-line dialog and drop-down, and also found David Cockey’s directions above helpful to resolve.
