3Dconnexion spacemouse, no roll axis rotation
Windows. Pitch and yaw work fine as do the translations, but roll (tilt) doesn’t work. It’s enabled in the 3Dconnexion driver and it works in other apps including Rhino 8.
Maybe there’s a setting I forgot about? I exported settings from v8 but when I tried to import them to v9 it hung.
It makes me a little seasick like this.
Thanks,
/B
Have you checked if the Lock Horizon switch is engaged? It is located in the “Popup Menu” inside the _SpaceMouse command in Rhino.
These settings seem to supercede or at least interact with the settings in the 3DConnexion settings panel.
That was it, I didn’t know there was a SpaceMouse command. Thanks.
