Space mouse all of a sudden …poooof doesn’t work. The plugin is installed . The menu that used to exist in document properties is no longer visible or accessible. The space mouse works everywhere else except in Rhino. I’ve reinstalled the mouse driver and nothing.
You should type in systeminfo into the command line. Copy and paste it here. Someone will look at it.—-Mark
found the fix: hold the SHIFT key while double-clicking the rhino.exe, it had a pop-up clicked ok then it was back to working fine
