3D to vectorised technical 2D pdf
Hi all,
I have a 3D construction that I want to export and use in Vectorworks. I have exported it as PDF and vectorised it etc. But it only works as wireframe. I would love to have it as TECHNICAL rather than Wireframe.
Can anyone help please?
Thanks!
I assume you are referring to the Technical working display mode.
That’s not possible using the display mode as it is a raster display mode.
Your best bet is to use the Make2D command, then assign the appropriate line type patterns to the resulting vectors that should show as hidden lines, and go from there.
