Hello! I am trying to add sensor point tags to grids that are associated to vertical walls.
I need the tags to face the same as the wall normals, so you can pan around the room and see all text tags at the same time. The closest I have gotten (shown in ship) orients them to a XZ or YZ plane, so some of the tags in the room aren’t facing the correct way and I have to switch back and forth between planes.
you could create planes with the same Y vector for all and adjust after the normal direction (unfortunate there is no component to adjust the Y direction).
