Okay having watched your full breakdown video Kyle… this is really cool. I like the ‘Halo’ as a display thing anyway for a start, that could totally make it in without the line tapers for me just as something that would probably be easier to see and work with on a daily basis.
I’d be tempted to just say keep it up… plus:
ZBuffer needs to just have a control for the min/max. Someone did a plugin IIRC with a slider, that should just be default rather than hidden away somewhere. When you showed the ZBuffer trick too occlude some of your sketch, I was genuinely really impressed. A great thought. See below:
Better use of viewport ZBuffer functionality please - #11 by Mahdiyar -
The undo stuff you mentioned within the command, seems a no brainer in a SketchMultiple, or something.
Fancy Lines by layer?
Then it seems like it would be a case of having shortcuts and highly interactive CPlane stuff. The Cplane ‘Elevation’ is a very useful command as an example, where you could quickly go from World Right >> to something in line with one of your wheels. A crazy off the bat idea would be something like, a CPlane which locks to be in front of the view, and you can visualise how ‘deep’ / far away it is by everything behind it being a certain colour, or transparency.
There’s that old CurveOnSurface plugin isn’t there. Could this ‘Sketch’ focus be something that brings Curve on Surface tools back the fore? This is something that is critical in footwear - the idea of a lightweight, easy to control curve with very few points, which is pulled (behind the scenes) to a complex surface. Make sense?
