Hi, I am currently working on printing a 3D model. I am using STL files, and have checked naked/manifold edges within rhino and it says there are currently none. However, when I import this file into ideamaker it lists manifold edges then does not print entire wall sections. I have attached the file here, please help!!
The file below is the foundation but the issue is the same throughout.
Hi Jack - I would UnGroup then BooelanUnion the parts of the house - start with the piles of boxes that are the stairs - make these union properly and then use MergeAllCoplanarFaces from time to time as you Union the objects - you’ll see that it fails from time to time and you’ll need to make adjustments - the goal is to have no interior faces.
