I am trying to create a 5-sided planar polygon.In the image I have various reference points shown in white. The white lines are all at the origin plane (Y=0). The blue lines are in a different plane.
I drew the top line segments along the top and right diagonal using known 3d points (The left blue diagonal is in the process of being drawn in the screen shot)
Then I do either set the CPlain to that object or the 3 points (same result either way).
Then I do ProjectOSnap enable
Now I want to close the curve so that, from the side view, it appears that its goes through the points circled. I don’t care what the Y value is as long as the X and Z values are the same as in the profile.
As shown, through my usage, Rhino insists on drawing the points projected to somewhere else.
(The diagonal line from the circled point is rhino’s projection line.)
How can I get a 3d polygon to match a 2d profile?
