3d model (solid) of an existing retaining wall with non-planar lines?
I have surveyed 3d-lines of an existing retaining wall. The lines are top front and bottom front of wall and non-parallell and non-planar. Is there a way to get a solid with for example a thickness of 0.3 meters to the backside of the retaining wall?
loft the curves or duplicate and trim the existing surface, then use offsetsrf you can flip the direction if needed
Surf offset does not work properly, I guess it’s because the lines are not straight and non-planar…
please post your file
Mur test.dwg (782.1 KB)
Red line is bottom front wall.
Hei Annette -
I’d offset the curves with the Loose option. Loft with straight sections or use EdgeSrf. Join and cap. You’ll need an EdgeSrf on the final non-planar cap.
MurTest - Maybe.3dm (2.5 MB)
Thanks a lot, this looks perfect.
