My model 3d is missing in rhino 7 , please why
Untitled.3dm (152.4 KB)
Thereās no sign of anything in the file, no. Itās also named āuntitledā, soā¦um what did you do?
Thanks for reply
I couldnāt connect it to vray for rhinoā¦then I lost the fileā¦but the file still has the 150 KB size that I was working onā¦I donāt know where it disappeared to
No thereās nothing in the file but the basic layers. Does not appear anything was ever saved, and not much is going to fit in 152kb.
You need to explain a lot better what you did. My response to every single sentence is āwhat do you mean by that? How? What exactly happened?ā Run systeminfo and post the results, I suppose.
EDIT: there is a bit of info in the file actually, and what it says is that maybe using a legit copy of Rhino might help.
In case you havenāt found the location for acquiring a valid licens yet: Rhino - Buy - Rhinoceros and after that download the official release from Rhino - Downloads
