I am referencing a 3d diagram of a roadway into another rhino file. If the cplane is changed or the referenced block is moved, the 3d geometry stays in the same place and the wire frame is moved. This is the first time this has happened and we’re really not sure what is causing this.
Hello - see if ClearAllMeshes
and then re-shade the view sorts it out.
No. It still looks the same.
Hello- can you please post the file or send to tech@mcneel.com, to my attention? I’ll take a look.
(turns out the objects were millions of units from the origin)
