3D designer for Awards medal
I am looking for a 3-D designer to help me create a file for a 3-D resin printer. I have started on a model that is four times the size of the original. My intention was to have it 3D scanned and then do some touchup with the file. After speaking with a couple companies that could provide the 3-D scan, they said they wouldn’t be able to transfer it into a 3-D software to make changes. They suggested to still have the 3-D scan done, but the designer would use this only as a reference. I have pictures I can provide of the model so far. It’s basically looks similar to an Olympic medal. I tried starting this last year, but ran out of time.
Isn’t this the same proposal that @theoutside offered you last year?
Hi Scott,
I would model the medal in Rhino 8, using the scan as a reference rather than converting it: clean NURBS for the disc, rim and lettering, and SubD for the softer sculpted relief. I would then scale it to the final size and export a watertight STL that is checked for your resin printer. My work has included preparing STL files for 3D printing and other fabrication files for 20 years, with 15+ years in Rhino and Grasshopper.
To give you a fixed price, could you send the photos of your model, the final diameter and thickness, any text or logos as vector files if you have them, and your deadline? The scan would help too. I will reply with a fixed price before any work starts.
Best, Björn
Björn Jelinek · PARAFLOW, Vienna · Rhino & Grasshopper training in Vienna and online | PARAFLOW
