I know you can do this in solidworks, but it has to be possible in rhino???
How make the curve in the middle, without extruding and project? I think its intersection curve in solidworks.
Thanks
Thanks
Hello - use TweenCurves
for this.
excellent thanks.
Not that command actually. I am trying to get the red middle intersection curve I created from two intersections, but without the extrusion > offset command. I know this can be done in other CAD programs, but maybe not Rhino? It would really only serve to save time in this domain.
Thanks.
I think you might want _Crv2View…
perfect, thanks.
okay second question:
I am drawing from plans: front, right, top, rear. How do I construct a curve from three different lines drawn on all planes? The line has 3 different dimensions, I can do a crv to crv, but how to interpolate all three?
thanks
Hello - hard to say from the image- feel free to post a file with the curves though.
Just point edit the degree 5 curve using the 4 view port lay out. Start with top view then side then front until the curve looks to be aligned in all three. I highly recommend this tutorial https://hkvertrieb.de/
