The height difference between the three different parts on the roof. I have built GH with kangaroo.
How can I control them with three points in GH. if not how do i achieve three different heights on the continuous undulating roof in Grasshopper.
also the additional goal is to cover it with equal shaped hexagons 10 m each in width, is Lunchbox best way to create it?
Seghier Thank you, I have one question. What are the two Crv defining? is it the outer edges of the surface?
The Expression and Deconstruct Arc commends are getting confused
For Crv I drew them in Rhino and clicked all three circles and assign them to both Crv on the command.
Was I supposed to assign one circle per Crv command? (you can’t draw actual curves with GH with Crv command, you can only assign them to existing Crv in Rhino) In GH file there are only two Crv commands
Kim one last question. The crv in GH is not matching the curve line I created in Rhino model
Once I assign the Crv command to the outline I want, DArc command fails (“Data conversion failed from Curve to Arc”)
How do I assign the Crv to the one outline I want?
