2Shapes and Rhino 7.0
Hi!
I’m trying to load 2Shapes (compiled in Rhino 6.0) in Rhino 7.0, and the Compatibility test failed. Is there a way to get more info?
Thanks,
Rafael
You can use our service https://compat.mcneel.com/
It will give you more info about your plug-in.
If you want to you can also share your plug-in directly with me so I can have a look why loading fails. In theory it should work, but maybe we broke the SDK somehow.
Done! :slight_smile: Now, it is running in Rhino 6.0 and Rhino 7.0! :rocket:
Thanks,
Rafa
Did we break our SDK? We would really appreciate it to know
Now! It was my fault! I thought I can load directly the plugin of 6.0 to 7.0. just I build it again with 7.0 dependencies, and it works! I didn’t change a line of code! Great job guys!!!
Thanks,
No, you should be able to load a plugin of 6.0 to 7.0 without rebuilding. That is what I’m trying to figure out.
