2nd filletEdge fails yet same item as first
V5,
Two fillet edges on my ‘egg’ insulator.
I have extended it Scale1D, then revamped the profiles for the altered half.
Being very careful, all goes well.
and now the cherry on the cake.
FilletEdge , the rad is 0.8mm chainEdges selected, get the continual line appear. then it fillets and removes the unwanted parts. :grinning_face:
The first worked a treat, and I get the end I wanted. :heart_eyes: Then do the second and it fails. :rage:
why ?
Its things like this that frustrate .
Try an explode and try to remove and join but fail.
second filletEdge fails yet same as first.3dm (1.0 MB)
Steve
Tried object intersection? Usually shows the curve where it fails to connect
What curve would that be ?
I shouldnt have to diesct the result and try and remove the unwanted bits.
Why does the FilletEdge fail to start with ?
it was just a solid , and the first edge worked, no different to the second edge.
Does Fusion360 or Solidworks have similar fails ?
Steve
The fillet fails but rhino makes it anyways try selecting that result and the egg then object intersection
It will reveal curves not intersecting or looks weird is what i suspect not allowing you to trim properly
Don’t have my laptop or i would have a better look srry :confused:
it was an ‘egg’ made by Jeremy, I just scaled it longer 1D, then using closed polys cut the two channels into it. the second cutter was also used on the forum, I didnt alter it at all. , no declared problems.
so why that second gulley from the second cutter is wonkey I just dont know.
all rails and sweeps were mega careful.
I challenge anyone to better this.
been using Rhino 10 yrs or so.
any more and its like defusing an atomic bomb.
ones brain is mega focused, eyes out on stalks,
simple stages.
Steve
R0.8 will stop here where the initial edge is no longer a pair of valid surfaces.
rhino 9 continue across faces … can handle it
here you are:
second filletEdge fails yet same as first_tom_p_fix_rh5.3dm (576.3 KB)
kind regards - tom
If you could lay off these “booleans” and “edges”, good old FilletSrf does the job just fine.
Funny story i learned recently…
Software like solidworks sometimes gives the illusion that fillets work
When it is in a production setting to have the correct measurements it’s important that they are correct.
Someone used fusion 360 as a “unf***” modell the fillets because sw and similar just breaks it
There are forum members saying this but I got to see it first hand for myself in the real world.
Rhino fails them but gives the math a visual where it fails and if the user understand what they are seeing why it fails, proper actions can be taken.
I’m repeating myself here but the grass is not always greener on the other side.
By the end of the day right commands and tools for the job is where it’s at
When time is money well @Lagom has the right answer in my view.
Hi
Tom, I use wip9 and it fails,
rad 0.8
chainedges yes, select edge get the continual line, enter enter and the fillet is within the original edge lurking inside.
I try for FilletSrf and as soon as I select first then second surface, though there are more surfaces to fillet, it does it and fails.
I am wanting a chain surfaces option, I dont like it when it just grabs the first two ,
select first surface for me neds to be the outside of the egg, then select second surface the various surfaces within the gulley.
so why does my wip9 fail ? its up to date.
surely FilletEdge should tackle this.
Steve
FilletSrf works also in Rhino 5. All you need to do is to click on the right surfaces between which the fillet surface shall be built. A fillet has nothing to do with edges. Hope the below explains it.
finally got some time to kill, pipe trim trick could this also work?
second filletEdge fails yet same as first pipe trim.3dm (4.9 MB)
Steve,
The second fillet is not the same as the first. The recess is made up of a series of polysurfaces. These have a narrow surface, as here:
paired with a wider surface on the other side:
On you first fillet, it fit within the narrow surface but on your second, where that surface is still narrower, it doesn’t fit within it and that is what causes it to fail. You can still fillet here with FilletEdge if you Explode the object, then Split all the recess pieces down the centreline (you could use the Isocurve option in Split), delete the pieces on the narrow surface side of the recess and mirror the other pieces across. Join everything again and the FilletEdge will now work:
second filletEdge succeeds even though different from first.3dm (1.4 MB)
Regards
Jeremy
OMG,
have collapsed on floor.
Can we have Rhino a bit more understanding on such things ?
WIP9 failed as well.
Update WIP9 intelligence, ask to select all possible surfaces involved in the fillet, then it does the mind bending stuff that mere mortals would fail at.
If anyone has Fusion360 or Solidworks, what do they do when the edge is selected ?
I am intrigues to know.
Also If I were to convert it to a mesh, is there a fillet Edge for a mesh, just thinking offPiste now !
Can one in fact convert an object to a mesh ? Then back again ? Then filletEdge ?
I cannot get to grips with FilletSrf, wish it chained surfaces.
Steve
No “booleans” or “edges” needed. FilletSrf just works. If your surfaces on both sides of the fillet chain are tangent to each other, you can use @Jim 's fabulous script to make it even easier.
If Jim’s script works and rhino 9 FilletSrf with continue across faces enabled does not, let me know. The script’s capabilities are in V9.
