2d section line weights
Hi all, I’m trying to generate 2d section from 3d model. I’m very happy to be able to give a pattern based on the layer or object. But I wonder how to assign different line weights to fill and section lines? this possibility is fundamental! Am I using the wrong method to automatically produce 2D drawings? Will it be implemented in V8?
You can either define the line weight per object by selecting it and going to the Properties: Object panel or for an entire layer and all objects on it in the Layers panel.
No idea. What method are you using?
By the way, if you want to preview the line weights in one or more views, you need to enable PrintDisplay. Otherwise, the line weights will only show up when you export a PDF from a layout or print it.
